RTOS Demo for RISC-V MiFive M2GL025 / Renode
This page documents a pre-configured
SoftConsole/GCC FreeRTOS project that originally
targeted the MiFive RISC-V core on the Microchip (previously MicroSemi)
M2GL025 Creative Board
from Future Electronics. The target was switched to the Renode software emulation
of the same board when the project became too large to run out of target RAM (which necessitated
using the FPGA tools to program the application onto the target hardware).
Renode is installed with SoftConole.
IMPORTANT! Notes on using the MiFive RISC-V port
- Instructions on using FreeRTOS on RISC-V cores
- Source code organisation
- The demo application functionality
- Building the RTOS demo application
- Running/debugging the RTOS demo in the Renode emulator
- RTOS configuration and usage details
Also see the FAQ
My application does not run, what could be wrong?.
If you want to go beyond just running the demo described on this page, or if you
want to create your own RISC-V FreeRTOS project, then please also read the documentation
page that provides
generic information
on running the FreeRTOS kernel on RISC-V cores.
The FreeRTOS zip file download contains the source code for all the FreeRTOS ports, and
to use the FreeRTOS Microchip (previously Microsemi) MiFive RISC-V demo.
See the
Source Code Organization page for information on the
zip file's directory structure. The MiFive RISV-C SoftConsole project is located
in the
/Demo/RISC-V_Renode_Emulator_SoftConsole directory. More information
is provided in the
build instructions
section below.
On RISC-V architectures the additional
freertos_risc_v_chip_specific_extensions.h header file
is used to extend the base RISC-V RTOS port to any chip specific extensions the target RISC-V
chip may implement. The RISC-V core used on the M2GL025 board does not implement any
registers over and above those defined by the base RISC-V architecture, and includes
a CLINT. Therefore this project uses the freertos_risc_v_chip_specific_extensions.h
header file from the /FreeRTOS/Source/portable/GCC/RISC-V/chip_specific_extensions/RV32I_CLINT_no_extensions
directory.
The Microchip MiFive RISC-V Demo Application
The constant
mainCREATE_SIMPLE_BLINKY_DEMO_ONLY, which is defined at the
top of
main.c, is used to switch between a simple 'blinky' style getting started project
and a more comprehensive test and demo application.
When
main() calls
main_blinky().
main_blinky() creates a basic example that uses two tasks and one queue.
The Queue Send Task:
The queue send task is implemented by the prvQueueSendTask() function.
The task sits in a loop sending the value 100 to the queue
every 1000 milliseconds (1 emulated second when running in
the Renode emulator).
The Queue Receive Task:
The queue receive task is implemented by the prvQueueReceiveTask()
function. The task sits in a loop that blocks on attempts to
read from the queue (no CPU cycles are consumed while the task is blocked),
writing 'blink' to the Renode console each time the value 100 is
received from the queue send task.
As the queue send task writes to the queue every 1000 emulated
milliseconds the queue receive task unblocks and writes to the Renode console
every 1000 emulated milliseconds (which may be different to real milliseconds).
When
main() calls
main_full().
main_full() implements a comprehensive test and demo application that demonstrates and/or
tests (among other things):
The created tasks are from the set of
standard demo
tasks. Standard demo tasks are used by all FreeRTOS port demo applications.
They have no specific functionality, and are created just to demonstrate how to use the FreeRTOS API,
and test the RTOS port.
A 'check' task is created that periodically inspects the standard
demo tasks (which contain self monitoring code) to ensure all the tasks are functioning
as expected. The check task outputs a '.' character or error message to the
Renode console each time it executes.
This gives visual feedback of the
system health. If the '.' appears on the console every 3 emulated seconds (which
will differ from actual seconds), then the
check task has not discovered any problems. If the console displays an error
message then the check task has
discovered a problem in one or more tasks.
Important note:
The project will not build if the directory structure is different to
the directory structure used in official FreeRTOS zip file releases.
Ensure the 'copy projects into workspace' check box is
not checked when importing the project into
the Eclipse workspace.
To open and build the M2GL025 MiFive RISC-V project:
Download and install the SoftConsole Eclipse based development tools.
Start SoftConsole and either select an existing or create a new workspace
when prompted.
Select "Import..." from the SoftConsole 'File' menu. The Import dialog box
will open.
In the Import dialog box, select "General->Existing Project into Workspace".
The Import Projects dialog box will open.
In the Import Projects dialog box, navigate to and select the
FreeRTOS/Demo/RISC-V_Renode_Emulator_SoftConsole
directory, and ensure the 'copy projects into workspace'
check box is not checked.
Selecting the directory and project in the Import Project
dialog box. Click to enlarge.
In the 'Projects' window of the Import Projects dialog box, select the RTOSDemo project, and click finish.
Select "Build all" from the SoftConsole 'Project' menu. The project should build
without any errors or warnings, outputting a file called RTOSDemo.elf.
The instructions below demonstrate how to first start Renode, and then start a debug
session that connects to Renode, all from within the SoftConsole IDE.
The Renode emulator has shipped with SoftConsole since SoftConsole version 6.0:
Select "External Tools->External Tools Configuration..." from the
SoftConsole 'Run' menu. The "Create, manage and run configurations" dialog will
open.
This step creates a menu item in the SoftConsole IDE that,
when clicked, starts the Renode emulator.
In the "Create, manage and run configurations" dialog, double click "Program" to add a
new configuration, then complete the configuration exactly as shown in the
image below (click the image for a larger view). The tabs not shown in the image can be left at their
default values.
Creating a configuration that starts the Renode emulator. Click
to enlarge.
Click 'Run' to check the configuration starts Renode. Close the dialog once
the configuration is able to
start Renode successfully. Note: It is always necessary to stop Renode
manually once it has been started, but for now, leave it running as it
is needed in the next step.
This step creates a debug launch configuration.
Right click the "RTOSDemo_Debug_Renode.launch"
file in the Eclipse project explorer, then select "Debug As->RTOSDemo_Debug_Renode"
from the pop up menu. The debugger should start and connect to Renode
(assuming the previous step left Renode running).
Creating a debug launch configuration. Click
to enlarge.
Once the launch configuration is able to successfully start a debug
session, stop the debug session again by selecting it in the Eclipse Debug view
then clicking the terminate speed button (which has a red square on it), then
shut down Renode by likewise selecting it in the Eclipse Debug view and
clicking the terminate speed button again.
Note: Stopping the debug
session does not automatically stop Renode, and Renode must be manually
stopped after each debug session. Failing to do this will result in high
CPU load and the inability to start any new debug sessions.
Terminating the debug session and Renode.
Now the configuration to start Renode, and the configuration to
start a debug session that connects to Renode, have both been created
and tested, this step links both configurations together.
Right click the "RTOSDemo-start-renode-emulator-and-attach.launch"
file in the Eclipse project explorer, then select "Debug As->RTOSDemo-start-renode-emulator-and-attach"
from the pop up menu. Renode should start, followed by the debug
session that connects to Renode.
Starting the Renode emulator and attaching the debugger
This section relates to the information provided on the
Running FreeRTOS on RISC-V Cores
documentation page:
Configuration items specific to this demo are contained in FreeRTOS/Demo/RISC-V_Renode_Emulator_SoftConsole/FreeRTOSConfig.h. The
constants defined in that file can be edited to suit your application. In particular, as the MiFive core includes a machine timer (MTIMER) configMTIME_BASE_ADDRESS and configMTIMECMP_BASE_ADDRESS are defined to 0xBFF8 and 0x4000 respectively, where PRCI_BASE is the base address of the clint as defined in the Microchip (previously Microsemi) SDK.
The MiFive core does not include any registers over and above those defined
by the base RISC-V architecture. The project therefore uses the
header file located in the /FreeRTOS/Source/portable/GCC/RISC-V/chip_specific_extensions/RV32I_CLINT_no_extensions directory,
so that directory is in the assembler's include path.
The interrupt handler provided in the MiFive software development kit (SDK)
is called handle_m_ext_interrupt, so the assembler's command line options include
-DportasmHANDLE_INTERRUPT=handle_m_ext_interrupt.
The file microsemi-riscv-renode.ld is a version of the linker
script provided with the board, edited to add the __freertos_irq_stack_top
linker variable necessary to ensure the stack that was used by main before
the scheduler starts is reused as the interrupt stack after the scheduler starts.
Other notes:
vPortEndScheduler() has not been implemented.
Source/Portable/MemMang/heap_4.c is included in the RISC-V project to provide the memory
full information.
At the time of writing, the demo does not support interrupt nesting.
