| Latest: FreeRTOS V7.1.1 was released May 1, 2012. View the change history. |
Renesas RX62N Demo using the IAR Embedded Workbench
| Build configuration | Description |
| Blinky | This is a very simple example that just creates two tasks. The tasks communicate via a queue, with an LED being toggled each time a correct and expected value is received from the queue. The Blinky build configuration uses main-blinky.c, the other two build configurations use main-full.c. |
| Debug | This is a more comprehensive demo that creates nearly 50 demo tasks. Two further tasks are then repeatedly creates and deleted as the application runs. The tasks consist mainly of the standard demo tasks - which don't perform any particular functionality other than testing the port (including interrupt nesting) and demonstrating how the FreeRTOS API is used. Information on additional tasks that are created is provided immediately below this table. |
| Debug_with_optimisation | This is very similar to the 'Debug' configuration, but includes an additional high frequency timer test. It also tests that the tasks and tests execute correctly when the optimiser is switched on. |
This only executes every five seconds but has the highest priority to ensure it gets CPU time. Its main function is to check that all the standard demo tasks are still operational. The check function writes to a status string that can be viewed at the very bottom of the "Task Stats" page served by the integrated web server. It also toggles LED5 if using the RSK, or LED9 if using the RDK. If the LED controlled by the check task is toggling once every five seconds then all the tasks are executing without any errors having been reported. If the toggle frequency increases to once every 200ms then an error has been detected in at least one task.
This is the task that runs the uIP TCP/IP stack. All network related processing is performed in this task, making the TCP/IP Flash and RAM footprint extremely small compared to other embedded TCP/IP implementations.
These two tasks fill the microcontroller registers with known values before checking that each register still contains the written value. The two tasks each use different known values. The tasks execute with a very low priority so will get preempted often. If a register ever contains an unexpected value then an error has occurred - probably in the context switching or interrupt mechanism. The reg test tasks write directly into registers and are therefore written in assembly code.
This test configures a timer to generate an interrupt at 20KHz. The interrupt priority is above configMAX_SYSCALL_INTERRUPT_PRIORITY so its timing should not be effected by the kernel. The jitter in the interrupt timing is measured and displayed at the bottom of the "Run Time Stats" page served by the integrated web server.
The served IO page
This sets the frequency of the RTOS tick. The supplied value of 1KHz is useful for testing the kernel functionality but is faster than most applications need. Lowering this frequency will improve efficiency.
This defines the interrupt priority used by the kernel for the timer and software interrupts. This should always be set to the lowest interrupt priority, which is 1 for the RX62N. See the configuration pages for more information.
This defines the maximum interrupt priority from which FreeRTOS API functions can be called. Interrupts at or below this priority can call FreeRTOS API functions provided that the API function ends in 'FromISR'. Interrupts above this priority cannot call any FreeRTOS API functions but will not be effected by anything the kernel is doing. This makes them suitable for functionality that requires very high temporal accuracy (motor control for example). The high frequency timer test included in the demo application uses a priority that is above configMAX_SYSCALL_INTERRUPT_PRIORITY. See the configuration pages for more information.
#pragma vector = VECT_CMT2_CMI2
__interrupt void vTimer2IntHandler( void )
/* ISR implementation goes here. This is the highest priority interrupt in
the demo so interrupts are just left disabled while the function executes. */
__enable_interrupt();
It is suggested that a compare match timer is used to generate the tick interrupt, and an example implementation of vApplicationSetupTimerInterrupt() that uses compare match timer 0 is included in both main-full.c and main-blinky.c within the demo application. The demo application defines configTICK_VECTOR within FreeRTOSConfig.h to be 28 (VECT_CMT0_CMI0 - the compare match 0 interrupt vector number). It is suggested that the provided example implementations are used in most cases.
