| Latest: FreeRTOS V7.1.1 was released May 1, 2012. View the change history. |
Renesas RX62N & RX63N using the Renesas Compiler and IDE
| Build configuration | Description |
| Blinky | This is a very simple example that just creates two tasks. The tasks communicate via a queue, with an LED being toggled upon each successful queue receive. The Blinky build configuration includes main-blinky.c, where as the other build configurations use main-full.c. |
| Debug | A very comprehensive demo that creates nearly 50 demo tasks before starting the scheduler, then continuously dynamically creates and deletes another two tasks as the application executes. The tasks consist mainly of the standard demo tasks - which don't perform any particular functionality other than testing the port (including interrupt nesting) and demonstrating how the FreeRTOS API can be used. Information on additional tasks that are created is provided immediately below this table. |
| Debug_with_optimisation | Adds a high frequency timer test to the tasks and tests executed by the Debug build configuration, plus tests that the tasks and tests execute correctly with the optimiser switched on. |
This only executes every five seconds but has the highest priority to ensure it gets processing time. Its main function is to check that all the standard demo tasks are still operational. The check function maintains a status string that can be viewed at the very bottom of the "Task Stats" page served by the integrated web server. It also toggles LED5 (RSK) or LED9 (RDK). If the check LED is toggling once every five seconds then all the demo tasks are executing without any errors having been reported. If the toggle frequency increases to once every 200ms then an error has been detected in at least one task.
This is the task that executes the TCP/IP stack. All network processing is performed in this task, making the TCP/IP Flash footprint extremely small when compared to other embedded TCP/IP stacks.
These two tasks fill the microcontroller registers with known values before checking that each register still contains its expected value. Each of the two tasks use different known values. The tasks run with very low priority so will get preempted very often. If a register ever contains an unexpected value then an error has occurred - probably in the context switching or interrupt mechanism. The reg test tasks write directly into specific registers, necessitates that they are written in assembly code.
This test configures a timer to generate an interrupt at 20KHz. The interrupt priority is above configMAX_SYSCALL_INTERRUPT_PRIORITY so should not be effected by anything else the kernel is doing. The jitter experienced in the interrupt timing is measured and displayed at the bottom of the "Run Time Stats" page served by the integrated web server.
The IP addresses used by the web browser and the RX62N development board must be compatible. This can be ensured by making the first three octets of both IP addresses the same. For example, if the web browser computer uses IP address 192.168.0.1, then the RX62N development board can be given any address in the range 192.168.0.2 to 192.168.0.254, other than any addresses that already exist on the same network.
An executing demo application should behave as follows (LED numbers are correct for the RSK, numbers in brackets are correct for the RDK):
The served IO page
This sets the frequency of the RTOS tick. The supplied value of 1000Hz is useful for testing the kernel functionality but is faster than most applications need. Lowering this frequency will improve efficiency.
This defines the interrupt priority used by the kernel for the timer and software interrupts. This should always be set to the lowest interrupt priority, which for the RX62N is 1. See the configuration pages for more information.
This defines the maximum interrupt priority from which FreeRTOS API functions can be called. Interrupts at or below this priority can call FreeRTOS API functions provided that the API function ends in 'FromISR'. Interrupts above this priority cannot call any FreeRTOS API functions but will not be effected by anything the kernel is doing. This makes them suitable for functionality that requires very high temporal accuracy. The high frequency timer test included in this demo application uses a priority that is above configMAX_SYSCALL_INTERRUPT_PRIORITY. See the configuration pages for more information.
re-enables interrupts on function entry. This will allow interrupts to nest
interrupt in the demo). */
See the examples provided by Renesas and the compiler
documentation for full details.
Often an ISR wants to cause a context switch so the task that is returned to when the ISR completes is different to the task that the ISR interrupted. This would be the case if the ISR caused a task to unblock, and the unblocked task had a priority above that of the task that was already in the Running state. This can be achieved by calling portYIELD_FROM_ISR(), which takes a single parameter. The parameter should be 0 if a context switch is not required, or non-zero if a context switch is required. This is demonstrated in the code below - which is a handler for a cascaded 8 bit timer 0 and timer 1 compare match interrupt.
re-enables interrupts on function entry. This will allow interrupts to nest. */
#pragma interrupt ( vT0_1InterruptHandler( vect = VECT_TMR0_CMIA0, enable ) )
void vT0_1InterruptHandler( void )
The application must define a function called vApplicationSetupTimerInterrupt() to configure the tick interrupt, then define configTICK_VECTOR to inform the kernel of the interrupt vector number of the chosen timer.
It is suggested that a compare match timer is used to generate the tick interrupt, and an example implementation of vApplicationSetupTimerInterrupt() that uses compare match timer 0 is included in both main-full.c and main-blinky.c within this demo application. The demo application defines configTICK_VECTOR within FreeRTOSConfig.h to be _CMT0_CMI0 (the compare match 0 interrupt vector number). It is suggested that the provided example implementations are used in most cases.
