Intertask Communications
Design concepts and performance optimisation
This page discusses the relationship between the different intertask communication API functions available under FreeRTOS - where a
fully featured, an
alternative, and a light weight API are provided.
The information below is intended to enable users to better select the API function to use under various
usage scenarios, especially with respect to:
- Function execution time.
- Interrupt responsiveness.
- Ease of use.
Outside of interrupt service routines, the fully featured API would be the normal choice for all but advanced users. It is simplest to use and makes
efficient use of critical sections.
Brief summary
The fully featured and alternative API provide the same functionality - but implemented in different ways.
The source code that implements the alternative (Alt) API is much
simpler because it executes everything from within a critical section.
This is the approach taken by many other RTOSes but is less sophisticated than the preferred fully featured API.
The fully featured API has more complex code that takes longer to execute, but makes much less use of
critical sections. Therefore the alternative API sacrifices interrupt responsiveness to gain API function execution speed,
whereas the fully featured API sacrifices API function execution speed to ensure better interrupt responsiveness.
The light weight API alternative offers even faster execution times, again at the expense of interrupt responsiveness
and also a little more complexity from the application writers point of view. Use of the light weight API is therefore considered
to be within the 'advanced topics' category, and is intended for the more experienced users only.
The API reference should be consulted for information of a more functional nature, for example, details of the function parameters.
Design goals and concepts
FreeRTOS was designed to have a small ROM footprint. To this end, all intertask communications are built around a single queue primitive - greatly limiting the amount of source
code required. Further to this,
all event management functionality is built into the queue data structures. This second point is contrary to other RTOS designs where an event control block
is often a separate entity in its own right.
The queue mechanism is used to implement:
- The queues themselves
- Semaphores - which are implemented as macros that uses queues and therefore introduce no new code
- Mutexes - which are also implemented as macros that use queues, introducing only a small amount of new code
FreeRTOS can easily be extended to include other intertask communication mechanisms in the same manner.
As all communication mechanisms are based on the same underlying queue concept, the API functions provided for each mechanism are in fact relatively
interoperable.
This relates to the following functions:
- xQueueSend()
- xQueueSendToBack()
- xQueueSendToFront()
- xQueueReceive()
- xQueuePeek()
- xSemaphoreTake()
- xSemaphoreGive()
Function characteristics
These functions are classed as fully featured for the following reasons:
- They utilise the queue and scheduler locking mechanisms. This allows the use of critical sections (within the API function itself) to be minimised -
ensuring minimum impact on interrupt responsiveness no matter how big the data being queued.
- They automatically cause a context switch should reading from or writing to the queue cause a task of higher priority to unblock.
- They are (naturally) thread safe.
- They are interrupt safe - in the sense that both a task and an interrupt can access the queue simultaneously. Please note that they are not
interrupt safe in the sense that they can be called from within an ISR, where only the light weight API must be used.
Being fully featured, these functions are internally complex, but this complexity is hidden from the user so they are simple to use.
The fully featured API functions take longer to execute than their alternative and light weight counterparts. This is because more code is required
for their implementation. We see therefore a trade off between function execution time and efficient use of critical sections.
Full featured API conclusions
When compared to the alternative and light weight API, the full featured API functions:
Have a lower impact on interrupt response times.
Are simpler to use. The kernel takes care of thread/interrupt safety, and task prioritisation.
Are larger, and therefore take longer to execute.
- xQueueAltSend()
- xQueueAltSendToBack()
- xQueueAltSendToFront()
- xQueueAltReceive()
- xQueueAltPeek()
- xSemaphoreAltTake()
- xSemaphoreAltGive()
Usage of these functions is demonstrated by the standard demo source files that have a filename starting "Alt", located in the FreeRTOS/Demo/Common/Minimal directory.
These API functions are functionally identical to their fully featured counterparts, but are implemented in a less sophisticated way.
They use crude critical sections in place of the queue and scheduler locking mechanisms utilised by their fully featured counterparts.
This simplifies the code and improves execution speed, but increases the amount of time spent inside critical sections and therefore
has a comparatively negative impact on interrupt response times. Also, unlike the fully featured versions, interrupts being disabled while
the queue is accessed means that interrupts and tasks cannot access the queue simultaneously.
The alternative API functions take less time to execute than the fully featured API functions, but more time to execute than their light weight counterparts.
Alternative API conclusions
When compared to the fully featured API, the alternative API functions:
Have a higher impact on interrupt response times.
Have equivalent function call prototypes so are therefore neither simpler nor more complex to use.
Are smaller, and therefore take less time to execute (although more time than the light weight alternatives).
- xQueueSendFromISR()
- xQueueSendToBackFromISR()
- xQueueSendToFrontFromISR()
- xQueueReceiveFromISR()
- xSemaphoreGiveFromISR()
These are the functions that can be used from within an ISR, and are named accordingly for ease of recognition. Please note however that
their use need not be restricted purely to within interrupts. They can be used within tasks in order to boost run time efficiency. More information is provided below.
- These functions are much simpler than their full featured or alternative versions. Their implementation uses less code and they therefore execute more quickly.
- They are designed to be safe for use within an interrupt so in themselves make no attempt to be interrupt safe. This means their use within an interrupt
is simple, but their use outside of an interrupt requires special consideration.
- They also do not automatically perform a context switch should reading or writing to the queue cause a task of higher priority to unblock. Instead they return
a value indicating whether or not a context switch is required.
The light weight functions provide more flexibility by leaving more decisions to the application writer. This provides the application designer greater choice in
trading off function execution time against interrupt responsiveness - but care needs to be taken in how this flexibility is used. More information is
provided on this in the following sections of this page.
Light weight API conclusions
When compared to the fully featured API, the light weight API functions:
Are simple to use when called from within an interrupt.
Are smaller, and more flexible. They therefore offer an opportunity to improve run time performance by allowing the application
designer to tailor the trade off between execution timing and interrupt responsiveness.
Require special consideration when called from a task, rather than an interrupt.
This information is intended for more experienced users only.
The following subsections detail how and where the light weight API functions can be used in place of their full featured and alternative versions. A series of examples demonstrate
different usage scenarios, starting from very basic fast use, then adding in more functionality.
Please note that these examples relate only to the use of the light weight API functions outside of an ISR. The API functions are named to include
the text "FromISR" to indicate that they are safe to use from within an ISR, not that they are exclusively for use inside an ISR.
Light weight example 1 - basic fast usage
The following code shows the fastest way of sending and receiving a message from one task to another:
void vAFunction( void )
/* Fast send to queue. Passing pdTRUE prevents the function
attempting to unblock a task. */
xQueueSendToFrontFromISR( pxQueue, pvItemToQueue, pdTRUE );
void vAnotherFunction( void )
/* Setting this to true will prevent the function attempting to
unblock a task. */
signed portBASE_TYPE x = pdTRUE;
/* Fast receive from queue. */
xQueueReceiveFromISR( pxQueue, pvBuffer, &x );
Listing 1: The fastest way to send or receive a message
The description of the light weight API above notes that, unlike the full featured variants, these API functions do not nothing to ensure thread or interrupt
safety.
Notes:
- The parameters passed to the functions in listing 1 prevent the functions from attempting to unblock any tasks that may be blocked waiting for queue events.
This means thread safety is not an issue when used with the cooperative scheduler - it does mean though that in this form the light weight API should only be used when the task accessing the other end of the queue
does so without blocking.
- In this form the API functions are not interrupt or preemption safe, meaning this is not an appropriate usage if an interrupt makes use of the same queue, or the task
accessing the queue could be preempted by a task that accesses the same queue.
Light weight example 2 - allowing tasks to be unblocked
The following code shows how Listing 1 can be extended to allow the light weight API functions to unblock a task.
/* Fast send to queue. Passing pdFALSE makes the function look
to see if a task requires unblocking. */
if( xQueueSendToFrontFromISR( pxQueue, pvItemToQueue, pdFALSE ) )
/* Writing to the queue unblocked a task of higher priority,
force a context switch. This would be done within the API
function if using the fully featured variant. */
taskYIELD();
/* Setting this to false will make the function look to see
signed portBASE_TYPE x = pdFALSE;
if( x == pdTRUE )
/* Reading from the queue unblocked a task of higher priority,
taskYIELD();
Listing 2: Unblocking tasks using the light weight API
Notes:
- We have done nothing between Listing 1 and Listing 2 to ensure interrupt safety. This is therefore still not appropriate usage if the queue is also accessed from an ISR.
- The parameters passed to the functions in listing 2 allow the functions to unblock any tasks that might be blocked waiting for queue events. This is therefore not appropriate
usage if using the preemptive scheduler. It provides a nice mechanism when using the co-operative scheduler only.
Light weight example 3 - introducing preemption and interrupt safety
The following code updates that presented in Listing 2 to make the light weight API usage both preemption and interrupt safe. The entire call to the API function is placed within
a critical section, adversely effecting interrupt response timing. This method therefore trades off interrupt response times for improved execution time, whereas the full
featured versions of these API functions do the opposite - they instead trade off execution time for improved interrupt response times.
portBASE_TYPE xYieldRequired;
to see if a task requires unblocking. Note the fully featured
version of this API function uses critical sections in a much
more efficient manner than this! */
taskENTER_CRITICAL();
xYieldRequired = xQueueSendToFrontFromISR( pxQueue, pvItemToQueue, pdFALSE );
taskEXIT_CRITICAL();
if( xYieldRequired )
taskYIELD();
/* Fast receive from queue. The full featured version
of this API function uses critical sections in a much more
if( x == pdTRUE )
taskYIELD();
Listing 3: Full preemption and interrupt safety - the full featured API versions do not execute the entire queue function in a critical section in the manner
shown here!
Notes:
- Macros can be provided to facilitate the use of the light weight API in this manner.
- Used in this way the light weight API provides similar functionality to the fully featured API versions, but with less efficient use of critical sections.
What about using semaphores and mutexes?
The principals demonstrated here for accessing queues also apply when accessing semaphores and mutexes.
Note that there is no xSemaphoreTakeFromISR() function, but as stated earlier, the design of FreeRTOS permits API functions to be used interoperable. You can therefore
uses xQueueReceiveFromISR() to 'take' a semaphore! Just pass in the semaphore handle in place of the queue handle.
Copyright (C) 2004-2010 Richard Barry. Copyright (C) 2010-2012 Real Time Engineers Ltd.
Any and all data, files, source code, html content and documentation included in the FreeRTOS
TM distribution or available on this site are the exclusive property of Real Time Engineers Ltd..
See the files license.txt (included in the distribution) and this
copyright notice for more information. FreeRTOS
TM and FreeRTOS.org
TM are trade marks of Real Time Engineers Ltd..
