RTOS Demo for RISC-V QEMU sifive_e Model
RISC-V HiFive SiFive QMEU
This page documents a pre-configured SiFive Freedom Studio project that builds and runs a FreeRTOS RISC-V demo in the sifive_e QEMU model using GCC and GDB.
  2. Source code organisation
  4. Building the RTOS demo application
  5. Running/debugging the RTOS demo in the QEMU emulator
The FreeRTOS zip file download contains the source code for all the FreeRTOS ports, and every demo application. That means it contains many more files than are required to use the FreeRTOS sifive_e QEMU RISC-V demo. See the Source Code Organization page for information on the zip file's directory structure. The sifive_e RISC-V QEMU Freedom Studio project is located in the /Demo/RISC-V-Qemu-sifive_e-FreedomStudio directory. More information is provided in the build instructions section below.
On RISC-V architectures the additional freertos_risc_v_chip_specific_extensions.h header file is used to extend the base RISC-V RTOS port to any chip specific extensions the target RISC-V chip may implement. The QEMU sive5_e model does not implement any registers over and above those defined by the base RISC-V architecture, and does emulate a CLINT. Therefore this project uses the freertos_risc_v_chip_specific_extensions.h header file from the /FreeRTOS/Source/portable/GCC/RISC-V/chip_specific_extensions/RV32I_CLINT_no_extensions directory.
The sifive_e QEMU RISC-V Demo Application
    The queue send task is implemented by the prvQueueSendTask() function. It sits in a loop, sending the value 100 to the queue every 1000 emulated milliseconds (1 emulated second).
    The queue receive task is implemented by the prvQueueReceiveTask() function. It sits in a loop that blocks on attempts to read from the queue (no CPU cycles are consumed while the task is blocked), writing 'blink' to the QEMU console each time the value 100 is received from the queue send task.
    As the queue send task writes to the queue every 1000 emulated milliseconds the queue receive task unblocks and writes to the QEMU console every 1000 emulated milliseconds.
A 'check' task is created that periodically inspects the standard demo tasks (which contain self monitoring code) to ensure all the tasks are functioning as expected. The check task outputs a '.' character or error message to the QEMU console each time it executes. This gives visual feedback of the system health. If the '.' appears on the console every 3 emulated seconds (which may be different to real seconds), then the check task has not discovered any problems. If the console displays an error message then the check task has discovered a problem in one or more tasks.
  1. Download and install the Freedom Studio development tools (scroll down to see software downloads).
  2. Start Freedom Studio and either select an existing or create a new workspace when prompted.
  3. Select "Import..." from the Freedom Studio 'File' menu. The Import dialog box will open.
  5. In the Import Projects dialog box, navigate to and select the FreeRTOS/Demo/RISC-V-Qemu-siFive_e-FreedomStudio directory, and ensure the 'copy projects into workspace' check box is not checked.
  6. In the 'Projects' window of the Import Projects dialog box, select the RTOSDemo project, and click finish.
  7. Select "Build all" from the Freedom Studio 'Project' menu. The project should build without any errors or warnings, and create a file called RTOSDemo.elf.
Running the RTOS demo application in the QEMU emulator
  1. Download QEMU. The project was created and tested using the pre-built Windows binaries.
  2. Use the command line below to start QEMU, replacing "path/to" with the real path to the RTOSDemo.elf output by the following the build instructions above:
    qemu-system-riscv32 -kernel path/to/RTOSDemo.elf -S -s -machine sifive_e
  3. Finally, right click the "Hardware_QEMU.launch" file in the Eclipse project explorer, then select "Debug As->Hardware_QEMU" from the pop up menu. The debugger should start and connect to QEMU (assuming the previous step left QEMU running).
    Creating a debug launch configuration. Click to enlarge.
  • Configuration items specific to this demo are contained in FreeRTOS/Demo/RISC-V-Qemu-sifive_e-FreedomStudio/FreeRTOSConfig.h. The constants defined in that file can be edited to suit your application. In particular, as the emulated SiFive core includes a machine timer (MTIMER)configMTIME_BASE_ADDRESS and configMTIMECMP_BASE_ADDRESS are defined to ( CLINT_CTRL_ADDR ) + 0xBFF8 and ( CLINT_CTRL_ADDR ) + 0x4000 respectively.
  • The emulated SiFive core does not include any registers over and above those defined by the base RISC-V architecture. The project therefore uses the freertos_risc_v_chip_specific_extensions.h header file located in the /FreeRTOS/Source/portable/GCC/RISC-V/chip_specific_extensions/RV32I_CLINT_no_extensions directory, so that directory is in the assembler's include path.
  • The interrupt handler provided in the SiFive software development kit (SDK) is called trap_handler, so the assembler's command line options include -DportasmHANDLE_INTERRUPT=handle_trap.
  • The file flash.lds is a version of the linker script provided with the development tools, edited to add the __freertos_irq_stack_top linker variable necessary to ensure the stack that was used by main before the scheduler starts is reused as the interrupt stack after the scheduler starts.
Other notes:
