xMessageBufferIsEmpty()
[RTOS Message Buffer API]
message_buffer.h
BaseType_t xMessageBufferIsEmpty( MessageBufferHandle_t xMessageBuffer );
Queries a message buffer to see if it is empty. A message buffer is empty if it does not contain any messages.
If the message buffer is empty then pdTRUE is returned. Otherwise pdFALSE is returned.
