xStreamBatchingBufferCreate / xStreamBatchingBufferCreateWithCallback
[RTOS Stream Buffer API]
stream_buffer.h
StreamBufferHandle_t xStreamBatchingBufferCreate( size_t xBufferSizeBytes,
                                                  size_t xTriggerLevelBytes );
StreamBufferHandle_t xStreamBatchingBufferCreateWithCallback(
Creates a new stream batching buffer using dynamically allocated memory. See xStreamBatchingBufferCreateStatic() for a version that uses statically allocated memory (memory that is allocated at compile time).
configSUPPORT_DYNAMIC_ALLOCATION must be set to 1 or left undefined in FreeRTOSConfig.h for xStreamBatchingBufferCreate() to be available. configUSE_STREAM_BUFFERS must be set to 1 in FreeRTOSConfig.h for xStreamBatchingBufferCreate() to be available. Additionally, configUSE_SB_COMPLETED_CALLBACK must be set to 1 in FreeRTOSConfig.h for xStreamBatchingBufferCreateWithCallback() to be available.
Enable stream buffer functionality by including the FreeRTOS/source/stream_buffer.c source file in the build.
The difference between a stream buffer and a stream batching buffer is when a task performs a read on a non-empty buffer:
  • A task that reads from a non-empty stream buffer returns immediately regardless of the amount of data in the buffer.
  • A task that reads from a non-empty stream batching buffer blocks until the amount of data in the buffer exceeds the trigger level or the block time expires.
xBufferSizeBytes
The total number of bytes the stream batching buffer will be able to hold at any one time.
xTriggerLevelBytes
The number of bytes that must be in the stream batching buffer to unblock a task calling xStreamBufferReceive before the block time expires.
The callback invoked when a number of bytes at least equal to the trigger level are sent to the stream batching buffer. If the parameter is NULL, it will use the default implementation provided by the sbSEND_COMPLETED macro. To enable the callback, configUSE_SB_COMPLETED_CALLBACK must be set to 1 in FreeRTOSConfig.h. The send completed callback function must have the prototype defined by StreamBufferCallbackFunction_t, which is:
void vSendCallbackFunction( StreamBufferHandle_t xStreamBuffer,
                            BaseType_t xIsInsideISR,
The callback invoked when more than zero bytes are read from a stream batching buffer. If the parameter is NULL, it will use the default implementation provided by the sbRECEIVE_COMPLETED macro. To enable the callback, configUSE_SB_COMPLETED_CALLBACK must be set to 1 in FreeRTOSConfig.h. The receive completed callback function must have the prototype defined by StreamBufferCallbackFunction_t, which is:
void vReceiveCallbackFunction( StreamBufferHandle_t xStreamBuffer,
If NULL is returned, then the stream batching buffer cannot be created because there is insufficient heap memory available for FreeRTOS to allocate the stream batching buffer data structures and storage area. The return of a non-NULL value indicates that the stream batching buffer has been created successfully - the returned value should be stored as the handle to the created stream batching buffer.
Example use:
void vAFunction( void )
StreamBufferHandle_t xStreamBatchingBuffer;
const size_t xStreamBufferSizeBytes = 100, xTriggerLevel = 10;
// Create a stream batching buffer that can hold 100 bytes. The memory used
// to hold both the stream batching buffer structure and the data in the stream
// batching buffer is allocated dynamically.
xStreamBatchingBuffer = xStreamBatchingBufferCreate( xStreamBufferSizeBytes, xTriggerLevel );
if( xStreamBatchingBuffer == NULL )
// There was not enough heap memory space available to create the
// stream batching buffer.
// The stream batching buffer was created successfully and can now be used.
