xStreamBufferReceive()
[RTOS Stream Buffer API]
stream_buffer.h
size_t xStreamBufferReceive( StreamBufferHandle_t xStreamBuffer,
                             void *pvRxData,
                             size_t xBufferLengthBytes,
                             TickType_t xTicksToWait );
Receives bytes from a stream buffer.
xStreamBuffer   The handle of the stream buffer from which bytes are to be received.
pvRxData   A pointer to the buffer into which the received bytes will be copied.
xBufferLengthBytes   The length of the buffer pointed to by the pvRxData parameter. This sets the maximum number of bytes to receive in one call. xStreamBufferReceive will return as many bytes as possible up to a maximum set by xBufferLengthBytes.
xTicksToWait   The maximum amount of time the task should remain in the Blocked state to wait for data to become available if the stream buffer is empty. xStreamBufferReceive() will return immediately if xTicksToWait is zero. The block time is specified in tick periods, so the absolute time it represents is dependent on the tick frequency. The macro pdMS_TO_TICKS() can be used to convert a time specified in milliseconds into a time specified in ticks. Setting xTicksToWait to portMAX_DELAY will cause the task to wait indefinitely (without timing out), provided INCLUDE_vTaskSuspend is set to 1 in FreeRTOSConfig.h. A task does not use any CPU time when it is in the Blocked state.
The number of bytes read from the stream buffer. This will be the number of bytes available up to a maximum of xBufferLengthBytes. For example:
  • If the trigger level is 1 (the trigger level is set when the stream buffer is created) -
    • If xBufferLengthBytes is 10 and the stream buffer contains 5 bytes when xStreamBufferReceive() is called - then xStreamBufferReceive() will not block, read 5 bytes from the buffer, and return 5.
    • If xBufferLengthBytes is 10 and the stream buffer contains 50 bytes when xStreamBufferReceive() is called - then xStreamBufferReceive() will not block, read 10 bytes from the buffer, and return 10.
    • If xBufferLengthBytes is 10, the stream buffer contains 0 bytes when xStreamBufferReceive() is called, xTicksToWait is 100, and 5 bytes are received into the buffer after 50 ticks - then xStreamBufferReceive() will enter the blocked state for 50 ticks (which is until data arrives in the buffer), after which it will read 5 bytes from the buffer, and return 5.
    • If xBufferLengthBytes is 10, the stream buffer contains 0 bytes when xStreamBufferReceive() is called, xTicksToWait is 100, and no bytes are received into the buffer within 100 ticks - then xStreamBufferReceive() will enter the blocked state for the full block time of 100 ticks, after which it will return 0.
  • If the trigger level is 6 -
    • If xBufferLengthBytes is 10, the stream buffer contains 0 bytes when xStreamBufferReceive() is called, xTicksToWait is 100, and 10 bytes are received into the buffer after 50 ticks - then xStreamBufferReceive() will enter the blocked state for 50 ticks (which is until at least the trigger level number of bytes arrives in the buffer), after which it will read 10 bytes from the buffer, and return 10.
    • If xBufferLengthBytes is 10, the stream buffer contains 0 bytes when xStreamBufferReceive() is called, xTicksToWait is 100, and 5 bytes are received into the buffer after 50 ticks - then xStreamBufferReceive() will remain blocked for the entire 100 tick block period (because the amount of data in the buffer never reached the trigger level), after which it will read 5 bytes from the buffer, and return 5.
void vAFunction( StreamBuffer_t xStreamBuffer )
uint8_t ucRxData[ 20 ];
size_t xReceivedBytes;
    /* Receive up to another sizeof( ucRxData ) bytes from the stream buffer.
    Wait in the Blocked state (so not using any CPU processing time) for a
    maximum of 100ms for the full sizeof( ucRxData ) number of bytes to be
    available. */
    xReceivedBytes = xStreamBufferReceive( xStreamBuffer,
                                           ( void * ) ucRxData,
                                           sizeof( ucRxData ),
                                           xBlockTime );
    if( xReceivedBytes > 0 )
        /* A ucRxData contains another xRecievedBytes bytes of data, which can
        be processed here.... */
