28 #ifndef IOT_LINEAR_CONTAINERS_H_ 29 #define IOT_LINEAR_CONTAINERS_H_ 32 #include "iot_config.h" 52 typedef struct IotLink
87 #define IOT_LINK_INITIALIZER { 0 } 88 #define IOT_LIST_DOUBLE_INITIALIZER IOT_LINK_INITIALIZER 89 #define IOT_DEQUEUE_INITIALIZER IOT_LINK_INITIALIZER 101 #if IOT_CONTAINERS_ENABLE_ASSERTS == 1 102 #ifndef IotContainers_Assert 103 #ifdef Iot_DefaultAssert 104 #define IotContainers_Assert( expression ) Iot_DefaultAssert( expression ) 106 #error "Asserts are enabled for containers, but IotContainers_Assert is not defined" 110 #define IotContainers_Assert( expression ) 120 #define IotLink_Container( type, pLink, linkName ) \ 121 ( ( type * ) ( void * ) ( ( ( uint8_t * ) ( pLink ) ) - offsetof( type, linkName ) ) ) 131 #define IotContainers_ForEach( pStart, pLink ) \ 132 for( ( pLink ) = ( pStart )->pNext; \ 133 ( pLink ) != ( pStart ); \ 134 ( pLink ) = ( pLink )->pNext ) 214 bool isLinked =
false;
218 isLinked = ( pLink->
pNext != NULL ) && ( pLink->
pPrevious != NULL );
246 pList->
pNext = pList;
268 while( pCurrent != pList )
271 pCurrent = pCurrent->
pNext;
290 return( ( pList == NULL ) || ( pList->
pNext == pList ) );
313 pHead = pList->
pNext;
366 pLink->
pNext = pHead;
371 pList->
pNext = pLink;
392 pLink->
pNext = pList;
396 pTail->
pNext = pLink;
445 int32_t ( * compare )(
const IotLink_t *
const pParam1,
const IotLink_t *
const pParam2 ) )
460 bool inserted =
false;
464 while( pCurrent != pList )
467 if( compare( pLink, pCurrent ) < 0 )
475 pCurrent = pCurrent->
pNext;
479 if( inserted ==
false )
524 pHead = pList->
pNext;
568 void ( * freeElement )(
void * pData ),
579 while( pCurrent != pList )
587 if( freeElement != NULL )
589 freeElement( ( ( uint8_t * ) pCurrent ) - linkOffset );
620 bool ( * isMatch )(
const IotLink_t *
const pOperationLink,
void * pCompare ),
627 bool matchFound =
false;
633 if( pStartPoint == NULL )
635 pCurrent = pList->
pNext;
639 while( pCurrent != pList )
642 if( isMatch != NULL )
644 matchFound = isMatch( pCurrent, pMatch );
648 matchFound = ( pCurrent == pMatch );
651 if( matchFound ==
true )
653 pMatchedLink = pCurrent;
657 pCurrent = pCurrent->
pNext;
687 bool ( * isMatch )(
const IotLink_t *
void * pCompare ),
696 if( pMatchedElement != NULL )
701 return pMatchedElement;
722 bool ( * isMatch )(
const IotLink_t *
void * pCompare ),
724 void ( * freeElement )(
void * pData ),
728 IotLink_t * pMatchedElement = NULL, * pNextElement = NULL;
738 if( pMatchedElement != NULL )
741 pNextElement = pMatchedElement->
pNext;
746 if( freeElement != NULL )
748 freeElement( ( ( uint8_t * ) pMatchedElement ) - linkOffset );
752 pMatchedElement = pNextElement;
754 }
while( pMatchedElement != NULL );
923 void ( * freeElement )(
void * pData ),
948 bool ( * isMatch )(
const IotLink_t *
void * pCompare ),
950 void ( * freeElement )(
void * pData ),
static void IotDeQueue_Remove(IotLink_t *const pLink)
Remove a single element from a queue.
Definition: iot_linear_containers.h:1061
static IotLink_t * IotDeQueue_PeekHead(const IotDeQueue_t *const pQueue)
Return an IotLink_t representing the element at the front of the queue without removing it...
Definition: iot_linear_containers.h:972
static IotLink_t * IotListDouble_RemoveFirstMatch(const IotListDouble_t *const pList, const IotLink_t *const pStartPoint, bool(*isMatch)(const IotLink_t *const pOperationLink, void *pCompare), void *pMatch)
Search a doubly-linked list for the first matching element and remove it.
Definition: iot_linear_containers.h:842
static bool IotListDouble_IsEmpty(const IotListDouble_t *const pList)
Check if a doubly-linked list is empty.
Definition: iot_linear_containers.h:443
static IotLink_t * IotListDouble_FindFirstMatch(const IotListDouble_t *const pList, const IotLink_t *const pStartPoint, bool(*isMatch)(const IotLink_t *const pOperationLink, void *pCompare), void *pMatch)
Search a doubly-linked list for the first matching element.
Definition: iot_linear_containers.h:775
static void IotListDouble_InsertBefore(IotLink_t *const pElement, IotLink_t *const pLink)
Insert an element before another element in a doubly-linked list.
Definition: iot_linear_containers.h:563
Link member placed in structs of a list or queue.
Definition: iot_linear_containers.h:52
static void IotDeQueue_EnqueueTail(IotDeQueue_t *const pQueue, IotLink_t *const pLink)
Add an element at the tail of the queue.
Definition: iot_linear_containers.h:1032
static IotLink_t * IotListDouble_PeekHead(const IotListDouble_t *const pList)
Return an IotLink_t representing the first element in a doubly-linked list without removing it...
Definition: iot_linear_containers.h:461
static void IotListDouble_RemoveAll(const IotListDouble_t *const pList, void(*freeElement)(void *pData), size_t linkOffset)
Remove all elements in a doubly-linked list.
Definition: iot_linear_containers.h:724
IotLink_t IotDeQueue_t
Represents a queue.
Definition: iot_linear_containers.h:68
static IotLink_t * IotListDouble_RemoveTail(const IotListDouble_t *const pList)
Remove the element at the tail of a doubly-linked list.
Definition: iot_linear_containers.h:698
static size_t IotListDouble_Count(const IotListDouble_t *const pList)
Return the number of elements contained in an IotListDouble_t.
Definition: iot_linear_containers.h:414
static void IotListDouble_InsertAfter(IotLink_t *const pElement, IotLink_t *const pLink)
Insert an element after another element in a doubly-linked list.
Definition: iot_linear_containers.h:577
static size_t IotDeQueue_Count(const IotDeQueue_t *const pQueue)
Return the number of elements contained in an IotDeQueue_t.
Definition: iot_linear_containers.h:940
static void IotDeQueue_EnqueueHead(IotDeQueue_t *const pQueue, IotLink_t *const pLink)
Add an element at the head of the queue.
Definition: iot_linear_containers.h:1002
struct IotLink * pNext
Pointer to the next element.
Definition: iot_linear_containers.h:55
static void IotListDouble_RemoveAllMatches(const IotListDouble_t *const pList, bool(*isMatch)(const IotLink_t *const pOperationLink, void *pCompare), void *pMatch, void(*freeElement)(void *pData), size_t linkOffset)
Remove all matching elements from a doubly-linked list.
Definition: iot_linear_containers.h:878
#define IotContainers_Assert(expression)
Assertion macro for the linear containers library.
Definition: iot_linear_containers.h:114
static IotLink_t * IotDeQueue_DequeueHead(const IotDeQueue_t *const pQueue)
Remove an element at the head of the queue.
Definition: iot_linear_containers.h:1019
static IotLink_t * IotListDouble_RemoveHead(const IotListDouble_t *const pList)
Remove the element at the head of a doubly-linked list.
Definition: iot_linear_containers.h:674
struct IotLink * pPrevious
Pointer to the previous element.
Definition: iot_linear_containers.h:54
static IotLink_t * IotListDouble_PeekTail(const IotListDouble_t *const pList)
Return an IotLink_t representing the last element in a doubly-linked list without removing it...
Definition: iot_linear_containers.h:488
static void IotDeQueue_Create(IotDeQueue_t *const pQueue)
Create a new queue.
Definition: iot_linear_containers.h:926
static void IotListDouble_InsertHead(IotListDouble_t *const pList, IotLink_t *const pLink)
Insert an element at the head of a doubly-linked list.
Definition: iot_linear_containers.h:511
static IotLink_t * IotDeQueue_PeekTail(const IotDeQueue_t *const pQueue)
Return an IotLink_t representing the element at the back of the queue without removing it...
Definition: iot_linear_containers.h:989
static void IotListDouble_Create(IotListDouble_t *const pList)
Create a new doubly-linked list.
Definition: iot_linear_containers.h:395
static IotLink_t * IotDeQueue_DequeueTail(const IotDeQueue_t *const pQueue)
Remove an element at the tail of the queue.
Definition: iot_linear_containers.h:1049
static bool IotLink_IsLinked(const IotLink_t *const pLink)
Check if an IotLink_t is linked in a list or queue.
Definition: iot_linear_containers.h:368
static void IotListDouble_InsertTail(IotListDouble_t *const pList, IotLink_t *const pLink)
Insert an element at the tail of a doubly-linked list.
Definition: iot_linear_containers.h:538
IotLink_t IotListDouble_t
Represents a doubly-linked list.
Definition: iot_linear_containers.h:62
static void IotDeQueue_RemoveAllMatches(const IotDeQueue_t *const pQueue, bool(*isMatch)(const IotLink_t *const pOperationLink, void *pCompare), void *pMatch, void(*freeElement)(void *pData), size_t linkOffset)
Remove all matching elements from a queue.
Definition: iot_linear_containers.h:1104
static void IotListDouble_Remove(IotLink_t *const pLink)
Remove a single element from a doubly-linked list.
Definition: iot_linear_containers.h:649
static void IotListDouble_InsertSorted(IotListDouble_t *const pList, IotLink_t *const pLink, int32_t(*compare)(const IotLink_t *const pParam1, const IotLink_t *const pParam2))
Insert an element in a sorted doubly-linked list.
Definition: iot_linear_containers.h:600
static void IotDeQueue_RemoveAll(const IotDeQueue_t *const pQueue, void(*freeElement)(void *pData), size_t linkOffset)
Remove all elements in a queue.
Definition: iot_linear_containers.h:1079
static bool IotDeQueue_IsEmpty(const IotDeQueue_t *const pQueue)
Check if a queue is empty.
Definition: iot_linear_containers.h:955
