Linear Containers API Reference
Linked lists and Queues
Declares and implements doubly-linked lists and queues. More...
#include "iot_config.h"
#include <stdbool.h>
#include <stddef.h>
#include <stdint.h>
Go to the source code of this file.
Data Structures | |
struct | IotLink_t |
Link member placed in structs of a list or queue. More... | |
Macros | |
#define | IOT_LINK_INITIALIZER { 0 } |
Initializer for an IotLink_t. | |
#define | IOT_LIST_DOUBLE_INITIALIZER IOT_LINK_INITIALIZER |
Initializer for an IotListDouble_t. | |
#define | IOT_DEQUEUE_INITIALIZER IOT_LINK_INITIALIZER |
Initializer for an IotDeQueue_t. | |
#define | IotContainers_Assert(expression) |
Assertion macro for the linear containers library. More... | |
#define | IotLink_Container(type, pLink, linkName) ( ( type * ) ( void * ) ( ( ( uint8_t * ) ( pLink ) ) - offsetof( type, linkName ) ) ) |
Calculates the starting address of a containing struct. More... | |
#define | IotContainers_ForEach(pStart, pLink) |
Iterates through all elements of a linear container. More... | |
Typedefs | |
typedef IotLink_t | IotListDouble_t |
Represents a doubly-linked list. | |
typedef IotLink_t | IotDeQueue_t |
Represents a queue. | |
Functions | |
static bool | IotLink_IsLinked (const IotLink_t *const pLink) |
Check if an IotLink_t is linked in a list or queue. More... | |
static void | IotListDouble_Create (IotListDouble_t *const pList) |
Create a new doubly-linked list. More... | |
static size_t | IotListDouble_Count (const IotListDouble_t *const pList) |
Return the number of elements contained in an IotListDouble_t. More... | |
static bool | IotListDouble_IsEmpty (const IotListDouble_t *const pList) |
Check if a doubly-linked list is empty. More... | |
static IotLink_t * | IotListDouble_PeekHead (const IotListDouble_t *const pList) |
Return an IotLink_t representing the first element in a doubly-linked list without removing it. More... | |
static IotLink_t * | IotListDouble_PeekTail (const IotListDouble_t *const pList) |
Return an IotLink_t representing the last element in a doubly-linked list without removing it. More... | |
static void | IotListDouble_InsertHead (IotListDouble_t *const pList, IotLink_t *const pLink) |
Insert an element at the head of a doubly-linked list. More... | |
static void | IotListDouble_InsertTail (IotListDouble_t *const pList, IotLink_t *const pLink) |
Insert an element at the tail of a doubly-linked list. More... | |
static void | IotListDouble_InsertBefore (IotLink_t *const pElement, IotLink_t *const pLink) |
Insert an element before another element in a doubly-linked list. More... | |
static void | IotListDouble_InsertAfter (IotLink_t *const pElement, IotLink_t *const pLink) |
Insert an element after another element in a doubly-linked list. More... | |
static void | IotListDouble_InsertSorted (IotListDouble_t *const pList, IotLink_t *const pLink, int32_t(*compare)(const IotLink_t *const pParam1, const IotLink_t *const pParam2)) |
Insert an element in a sorted doubly-linked list. More... | |
static void | IotListDouble_Remove (IotLink_t *const pLink) |
Remove a single element from a doubly-linked list. More... | |
static IotLink_t * | IotListDouble_RemoveHead (const IotListDouble_t *const pList) |
Remove the element at the head of a doubly-linked list. More... | |
static IotLink_t * | IotListDouble_RemoveTail (const IotListDouble_t *const pList) |
Remove the element at the tail of a doubly-linked list. More... | |
static void | IotListDouble_RemoveAll (const IotListDouble_t *const pList, void(*freeElement)(void *pData), size_t linkOffset) |
Remove all elements in a doubly-linked list. More... | |
static IotLink_t * | IotListDouble_FindFirstMatch (const IotListDouble_t *const pList, const IotLink_t *const pStartPoint, bool(*isMatch)(const IotLink_t *const pOperationLink, void *pCompare), void *pMatch) |
Search a doubly-linked list for the first matching element. More... | |
static IotLink_t * | IotListDouble_RemoveFirstMatch (const IotListDouble_t *const pList, const IotLink_t *const pStartPoint, bool(*isMatch)(const IotLink_t *const pOperationLink, void *pCompare), void *pMatch) |
Search a doubly-linked list for the first matching element and remove it. More... | |
static void | IotListDouble_RemoveAllMatches (const IotListDouble_t *const pList, bool(*isMatch)(const IotLink_t *const pOperationLink, void *pCompare), void *pMatch, void(*freeElement)(void *pData), size_t linkOffset) |
Remove all matching elements from a doubly-linked list. More... | |
static void | IotDeQueue_Create (IotDeQueue_t *const pQueue) |
Create a new queue. More... | |
static size_t | IotDeQueue_Count (const IotDeQueue_t *const pQueue) |
Return the number of elements contained in an IotDeQueue_t. More... | |
static bool | IotDeQueue_IsEmpty (const IotDeQueue_t *const pQueue) |
Check if a queue is empty. More... | |
static IotLink_t * | IotDeQueue_PeekHead (const IotDeQueue_t *const pQueue) |
Return an IotLink_t representing the element at the front of the queue without removing it. More... | |
static IotLink_t * | IotDeQueue_PeekTail (const IotDeQueue_t *const pQueue) |
Return an IotLink_t representing the element at the back of the queue without removing it. More... | |
static void | IotDeQueue_EnqueueHead (IotDeQueue_t *const pQueue, IotLink_t *const pLink) |
Add an element at the head of the queue. More... | |
static IotLink_t * | IotDeQueue_DequeueHead (const IotDeQueue_t *const pQueue) |
Remove an element at the head of the queue. More... | |
static void | IotDeQueue_EnqueueTail (IotDeQueue_t *const pQueue, IotLink_t *const pLink) |
Add an element at the tail of the queue. More... | |
static IotLink_t * | IotDeQueue_DequeueTail (const IotDeQueue_t *const pQueue) |
Remove an element at the tail of the queue. More... | |
static void | IotDeQueue_Remove (IotLink_t *const pLink) |
Remove a single element from a queue. More... | |
static void | IotDeQueue_RemoveAll (const IotDeQueue_t *const pQueue, void(*freeElement)(void *pData), size_t linkOffset) |
Remove all elements in a queue. More... | |
static void | IotDeQueue_RemoveAllMatches (const IotDeQueue_t *const pQueue, bool(*isMatch)(const IotLink_t *const pOperationLink, void *pCompare), void *pMatch, void(*freeElement)(void *pData), size_t linkOffset) |
Remove all matching elements from a queue. More... | |
#define IotContainers_Assert | ( | expression | ) |
Set IOT_CONTAINERS_ENABLE_ASSERTS to 1
to enable assertions in the linear containers library.
[in] | expression | Expression to be evaluated. |
#define IotLink_Container | ( | type, | |
pLink, | |||
linkName | |||
) | ( ( type * ) ( void * ) ( ( ( uint8_t * ) ( pLink ) ) - offsetof( type, linkName ) ) ) |
[in] | type | Type of the containing struct. |
[in] | pLink | Pointer to a link member. |
[in] | linkName | Name of the IotLink_t in the containing struct. |
#define IotContainers_ForEach | ( | pStart, | |
pLink | |||
Container elements must not be freed or removed while iterating.
[in] | pStart | The first element to iterate from. |
[out] | pLink | Pointer to a container element. |
inlinestatic |
[in] | pLink | The link to check. |
true
if pCurrent
is linked in a list or queue; false
otherwise.
inlinestatic |
This function initializes a new doubly-linked list. It must be called on an uninitialized IotListDouble_t before calling any other doubly-linked list function. This function must not be called on an already-initialized IotListDouble_t.
This function will not fail. The function IotListDouble_RemoveAll may be called to destroy a list.
[in] | pList | Pointer to the memory that will hold the new doubly-linked list. |
inlinestatic |
[in] | pList | The doubly-linked list with the elements to count. |
inlinestatic |
[in] | pList | The doubly-linked list to check. |
true
if the list is empty; false
otherwise.
inlinestatic |
[in] | pList | The list to peek. |
NULL
if the list is empty. The macro IotLink_Container may be used to determine the address of the link's container.
inlinestatic |
NULL
inlinestatic |
[in] | pList | The doubly-linked list that will hold the new element. |
[in] | pLink | Pointer to the new element's link member. |
inlinestatic |
[in] | pList | The double-linked list that will hold the new element. |
inlinestatic |
[in] | pElement | The new element will be placed before this element. |
inlinestatic |
[in] | pElement | The new element will be placed after this element. |
inlinestatic |
Places an element into a list by sorting it into order. The function compare
is used to determine where to place the new element.
[in] | pList | The list that will hold the new element. |
[in] | compare | Determines the order of the list. Returns a negative value if its first argument is less than its second argument; returns zero if its first argument is equal to its second argument; returns a positive value if its first argument is greater than its second argument. The parameters to this function are IotLink_t, so the macro IotLink_Container may be used to determine the address of the link's container. |
inlinestatic |
[in] | pLink | The element to remove. |
inlinestatic |
[in] | pList | The doubly-linked list that holds the element to remove. |
NULL
inlinestatic |
NULL
inlinestatic |
[in] | pList | The list to empty. |
[in] | freeElement | A function to free memory used by each removed list element. Optional; pass NULL to ignore. |
[in] | linkOffset | Offset in bytes of a link member in its container, used to calculate the pointer to pass to freeElement . This value should be calculated with the C offsetof macro. This parameter is ignored if freeElement is NULL or its value is 0 . |
inlinestatic |
If a match is found, the matching element is not removed from the list. See IotListDouble_RemoveFirstMatch for the function that searches and removes.
[in] | pList | The doubly-linked list to search. |
[in] | pStartPoint | An element in pList . Only elements between this one and the list tail are checked. Pass NULL to search from the beginning of the list. |
[in] | isMatch | Function to determine if an element matches. Pass NULL to search using the address pMatch , i.e. element == pMatch . |
[in] | pMatch | If isMatch is NULL , each element in the list is compared to this address to find a match. Otherwise, it is passed as the second argument to isMatch . |
NULL
if no match is found. The macro IotLink_Container may be used to determine the address of the link's container.
inlinestatic |
An IotLink_t may be passed as pList
to start searching after the head of a doubly-linked list.
NULL
inlinestatic |
inlinestatic |
Create a new queue.
This function initializes a new double-ended queue. It must be called on an uninitialized IotDeQueue_t before calling any other queue function. This function must not be called on an already-initialized IotDeQueue_t.
[in] | pQueue | Pointer to the memory that will hold the new queue. |
inlinestatic |
[in] | pQueue | The queue with the elements to count. |
inlinestatic |
[in] | pQueue | The queue to check. |
true
if the queue is empty; false
otherwise.
inlinestatic |
[in] | pQueue | The queue to peek. |
NULL
if the queue is empty. The macro IotLink_Container may be used to determine the address of the link's container.
inlinestatic |
NULL
inlinestatic |
[in] | pQueue | The queue that will hold the new element. |
inlinestatic |
[in] | pQueue | The queue that holds the element to remove. |
NULL
inlinestatic |
inlinestatic |
NULL
inlinestatic |
inlinestatic |
[in] | pQueue | The queue to empty. |
[in] | freeElement | A function to free memory used by each removed queue element. Optional; pass NULL to ignore. |
inlinestatic |
[in] | pQueue | The queue to search. |
[in] | pMatch | If isMatch is NULL , each element in the queue is compared to this address to find a match. Otherwise, it is passed as the second argument to isMatch . |
