Linear Containers API Reference
Linked lists and Queues
Configuration settings of the linear containers library.
Configuration settings are C pre-processor constants. They can be set with a #
in the config file (define
iot_config.h
) or by using a compiler option such as -D
in gcc. If a configuration setting is not defined, the library will use a "sensible" default value (unless otherwise noted). Because they are compile-time constants, a library must be rebuilt if a configuration setting is changed.
Set this to 1
to perform sanity checks when using linear containers.
Asserts are useful for debugging, but should be disabled in production code. If this is set to 1
, IotContainers_Assert can be defined to set the assertion function; otherwise, the Iot_DefaultAssert will be used.
Possible values: 0
(asserts disabled) or 1
(asserts enabled)
Recommended values: 1
when debugging; 0
in production code.
Default value (if undefined): 0
Assertion function used when IOT_CONTAINERS_ENABLE_ASSERTS is 1
Possible values: Any function with the same signature as the standard library's assert function.
Default value (if undefined): Iot_DefaultAssert if IOT_CONTAINERS_ENABLE_ASSERTS is 1
; otherwise, nothing. If Iot_DefaultAssert is not defined when asserts are enabled, the containers library will fail to build.
